Engine Head Pressure Cap?
Old Apr 16, 2009 | 07:17 PM
4life's Avatar
Question Engine Head Pressure Cap?
2001 S80 T6 was burning oil from engine compartment. Lifted the hood and discovered one of the two metal caps on the engine head had come almost completely off and was allowing the oil to escape and burn off on the engine. Are these caps pressure relief caps and what could cause only one of two (the other is completely seated and flush with the head) to come off? Are they sealed with a gasket?
Old Apr 16, 2009 | 07:22 PM
Most likely the crank case system is clogged.
They are pressed in there like freeze plugs are in the block.
The bad part is the proper way to install them is to remove the cam cover and tap it in from the back side.
Incursus
Jul 9, 2015 01:48 AM
shai_kino
Aug 20, 2014 06:45 AM
VTBricked
Sep 12, 2012 09:18 PM
dfilloux
2001-2013 model year V70
Jun 12, 2012 05:04 PM
stugilmour
Feb 15, 2011 11:44 PM
