Engine Stabiliser Brace
Old Oct 3, 2010 | 07:19 PM
howardr's Avatar
Default Engine Stabiliser Brace
Can anyone tell me whether or not the engine stabilser brace should have any play in it, and if so, how much?
I am wondering because mine has quite a bit of movement, and since my next job is to replace the 3 engine mounts, do I need to replace the brace or its bushings as well.
Thanks.
Old Oct 3, 2010 | 09:44 PM
SACS80's Avatar
I replaced my bushings with ones I got from IPD a year ago. From what I can remember there is less than 1/2" of movement. What's that stats on your ride?
Old Oct 4, 2010 | 07:02 AM
jlewisinsyr's Avatar
If you're referring to the top brace, yes, it will have play in it. You can buy a retro-fit kit that will firm it up though and will make it more rigid like a strut bar. You'll suffer a little in vibration, but it will firm up the front end (just depends on what you seek).
Old Oct 4, 2010 | 01:18 PM
howardr's Avatar
Thanks again guys.
2002 S80 T6. 117k. I've had it since it was a newborn, and I am not ready to let it go. This year, it got a new timing belt, water pump, power steering pump, battery, alternator, ignition coils and probably some other stuff I can't remember.
I am going to order the bushings and all the motor mounts from IPD today. Hopefully, a more stable engine will keep more things from falling apart.
Any more advice?
info2x
Nov 16, 2006 11:35 AM
Naf
Suspension
Oct 31, 2006 12:17 PM
rejeep
Oct 22, 2005 06:56 PM
SteveP
May 24, 2005 07:47 PM
reg
Jan 14, 2005 02:19 PM
