Front Axle Ping
Old Sep 25, 2010 | 09:17 PM
537playing's Avatar
Default Front Axle Ping
There is a TSB about this ping. It states to pull the axle away from the hub and use 'metal adhesive' and then let sit for six hours for it to dry. I just replaced both axles and will hear this ping occasionally. Has anyone used this adhesive? Is this the right solution?
Old Sep 25, 2010 | 09:32 PM
Yes it works! It is like a metal glue it holds it tight but is a major pain to remove the axle again later.
You might be able to use a medium loctite and get the same results and it not be as hard to remove it later.
Old Sep 25, 2010 | 09:38 PM
537playing's Avatar
Thanks Tech,
but how much is needed? You mention loctite, but I thought that was for threads?
Old Sep 25, 2010 | 09:44 PM
I have used it on axles before.
Believe my that Volvo stuff locks the axles really good. IMO it locks it to much.
I have had to use a Brass punch and small sledge hammer to get some back out of the hub. I am always worried about damaging a wheel bearing hammering them out.
I do believe the loctite is almost like the sealer for the oil pan and cam cover. Once the air is removed from the area around it the loctite gets hard.(But I know it does work on axles)
SilverTank
Jul 26, 2015 09:43 AM
rspi
Dec 10, 2011 10:58 PM
Padrea
Sep 20, 2008 07:55 PM
ikes4ever
Jan 20, 2008 06:17 AM
mrscullini
Oct 30, 2007 11:23 PM
