Front end vibration on braking
Old Jan 13, 2011 | 01:11 PM
A MAL3 NURSE's Avatar
Default Front end vibration on braking
Hey guys,
Got my car back today. I had a hard shift twice from first to second twice as I left the dealership and I almost crapped my pants, but it didn't happen again after that so my BP went down..lol...
Anyway, I notice the front end seems to vibrate a good bit when I break. Any ideas what it could be? Brakes and suspension checked out on the used car inspection sheet.
Old Jan 13, 2011 | 07:46 PM
537playing's Avatar
I would suggest looking at the rubber bushings on your lower control arms.
Old Jan 13, 2011 | 07:52 PM
Let me make a quick correction i feel vibration in the steering wheel and on the brake peddle when I press them. I guess I just assumed it was comming from the front. It may be, but the vibration is in the steering wheel mostly
Old Jan 13, 2011 | 08:54 PM
jlewisinsyr's Avatar
Your brakes could have sufficient pad depth, but it doesn't mean your rotors are not warped. Often people will just throw brake pads onto a car when the pads are low, but if you don't resurface the rotors or replace them, you often will get vibrations when braking, often severe.
Rotor warping may not be clearly visible in inspection on the car, where pad depth is quite obvious.
Old Jan 13, 2011 | 10:18 PM
chlacrosse14's Avatar
sounds like rotors to me. if you can find a place that will grind down the uneven parts that will be much cheaper than replacing. quick fix if they aren't too warped.
Old Jan 14, 2011 | 06:43 AM
Makes sense. I'll get them checked and report back!
chris81964
Jul 14, 2012 03:17 PM
grosseile88
Sep 10, 2011 11:29 AM
lschneider
Aug 28, 2008 05:50 PM
ocean238
Apr 17, 2008 06:20 PM
JimKW
Jun 14, 2005 06:38 PM
