2001 S60 2.4T front end vibrates on braking over 60 MPH
Old Jul 13, 2012 | 07:42 PM
chris81964's Avatar
Default 2001 S60 2.4T front end vibrates on braking over 60 MPH
Let me start by thanking all that contribute to this forum. It has been a resource that has saved me thousands of dollars.
I own a 2001 that I purchased in March 2012. I have put almost 10000 miles on it since I got it. I have a problem that I am at a loss to fix. anytime I try to brake (also called slowing down) at speeds over 60 MPH I get a violent shaking of the front of the car. It stops once the speed drops below 60 MPH. It is so violent that the wheel and the whole front end shakes.
Any ideas? I replaced the passenger side CV joint with one I got from FCP.
I appreciate any suggestions and help.
Old Jul 13, 2012 | 08:56 PM
Nichals's Avatar
check your sub frame bushings and buy these (if they are in good shape or not)
IPD Poly Subframe Bushing Insert Kit
Old Jul 13, 2012 | 09:09 PM
purv420's Avatar
Could be warped rotors or bad tires
Old Jul 13, 2012 | 09:31 PM
Nichals's Avatar
bad tires would most likely present a problem while cruising and accelerating, bad rotors would be bad at any speed. however related to tires, if they are in fact wearing weird (heavy on one side, feather ect.) it could be a suspension/alignment problem which could also cause the shaking.
on the flip side, is the shaking mostly in the brake, steering wheel, or whole front end of the car?
Old Jul 14, 2012 | 06:54 AM
chris81964's Avatar
Whole front end and steering wheel. Goes away once speed drops below 60 or I pushhard on the brake pedal
Old Jul 14, 2012 | 03:17 PM
Nichals's Avatar
still sounds like the sub frame bushings or even the lower control arms, they tend to go quickly
wjwolfe82
Mar 19, 2015 10:21 AM
dumbo
Aug 22, 2012 03:31 PM
grosseile88
Sep 10, 2011 11:29 AM
A MAL3 NURSE
Jan 14, 2011 06:43 AM
lschneider
Aug 28, 2008 05:50 PM
