front wheel bearing
Old May 16, 2012 | 11:13 AM
Falasi4's Avatar
Default front wheel bearing
I'm pretty sure I've got a front wheel bearing going - I've had them before on other cars and it's the same noise.
My question is:
How much has to come apart to just change the bearing/hub?
this is an example of the part I'm looking at - looks like 4 bolts:
eEuroparts - Front Wheel Bearing - # 274298
I've seen some posts/videos on this that make it look like you have to take a lot more apart than what I've previously done on other cars which is pull the wheel, pull the caliper/disk, take big axle nut off, unbolt bearing/hub.
Thanks!
Old May 22, 2012 | 11:28 AM
Falasi4's Avatar
anyone.... anyone... Beuller...?
Old May 30, 2012 | 09:07 PM
lonestar245's Avatar
I replace one on the front of my 02 S80. I seem to recall I had to pull the strut knuckle (wheel bearing housing?), so that means disconnecting the two lower strut bolts, the ball joint, the anti-lock sensor, the caliper, disc, and axle bolt- and not necessarily in that order. I remember having the knuckle in a vise when I pulled the bearing bolts.
I suppose if one could just remove the disc and caliper, and the axle bolt, one might be able to work behind the knuckle and get the 4 bolts out and slide the bearing off the axle stub. I just seem to recall the clearance for working back there was minimal at best- might be more trouble than tearing it all down.
I seem to recall I bought the cheapest NAPA hub assembly- $115- and it has a 12 month warranty.
oovvutt
Sep 22, 2014 12:50 PM
papa4scl
Aug 8, 2008 10:36 PM
jfikentscher
May 7, 2008 09:49 PM
98v70
Feb 7, 2008 08:01 PM
swede850T
Nov 4, 2005 09:29 PM
