Fuel Pump nut tool replacement?
Old Jul 16, 2010 | 05:01 PM
fusselman's Avatar
Default Fuel Pump nut tool replacement?
Hi,
I'm replacing my fuel pump (cracked plastic on outlet nipple). I see VADIS calls for special tool to remove nuts holding pump and cover on left side in. I forged ahead without the tool, but can't remove nut.
Any suggestions for common tool to remove these, without time and expense of buying volvo special tool 999-5720?
Thanks
eric.
Old Jul 16, 2010 | 06:27 PM
Dealer_Tech's Avatar
I have never removed a pump without the tool and pretty much doubt it can be securely locked in place sealing the pump/o-ring without it.
Old Jul 18, 2010 | 08:44 PM
fusselman's Avatar
Default What worked....
I purchased a generic in tank fuel pump spanner wrench at the main napa in my town (the branch locations were no help)... It worked quite well, after I ground it down in order to fit the volvo rings. was $18
neokhz
2001-2013 model year V70
Feb 24, 2024 03:10 PM
spidersilva
Aug 17, 2011 07:23 PM
zero324
Oct 28, 2010 08:04 AM
dtupac
Feb 19, 2007 10:14 PM
