gear stuck on park
s80
I have the same year car and the same thing happened to me. Don’t know if it will be the same issue for you but the button on the shift lever is plastic to metal and mine cracked and it wouldn’t lift the pin to shift out of park. I took the button out and inside behind it, I barely had to lift on the pin. I drove like that for a year and finally installed a new button. Other than that I believe you can pull the plate off and look further. Where the gear icons are below shifter.
