Having Headlight Problems again.
Old Mar 23, 2008 | 12:30 PM
Ahmed's Avatar
Default Having Headlight Problems again.
99 S80 2.9 132k miles
In the last 1 year I replaced both headlights and also something called a register at the dealership because of the headlights not working. And I also replaced somthing called the relay at the dealership because of the headlights not working again. And sometimes light now when I start the car I see a message called low beam light blown with the lights not working but after a short time the lights come back again. Any idea's what could be wrong this time.
And also the car still was the original ABS module at 132k miles because I never had any problem with it. So might this be a sign that the ABS module is going bad.
Old Mar 27, 2008 | 01:23 PM
Ahmed's Avatar
Default RE: Having Headlight Problems again.
Does tech or anyone have any idea's of what could be wrong. The dealersays they will charge $115 just to find out what the problem is.
Old Apr 12, 2008 | 01:40 PM
Ahmed's Avatar
Can tech or anyone help me out on this. My headlights are not working at all now for the last two days. Again i replace both headlights, the register and the relay within the last year. Any idea on what the problem might be.
Old Apr 12, 2008 | 11:01 PM
The shunt might be burnt.
I would look under the dash and see.
Old Apr 12, 2008 | 11:27 PM
Ahmed's Avatar
May i know where it is located under the dash. The driver side or the passenger side.
Old Apr 13, 2008 | 08:41 AM
It is under the drivers side. Once you remove the lower dash panel 2 torxes 25 screws you will see a computer looking thing on the left side kind of like by the body.
That is where the shut is located use link below to direct you to the one it should be.
http://www.xenonvalot.com/xenonfixvolvo.html
Old Apr 13, 2008 | 08:54 PM
Ahmed's Avatar
Ok here is an update, I went out tonight and the headlights started to work again after two days. But this is what keeps on happening, sometimes they dont work and sometimes they come back again. Assuming it is a burnt shunt, any idea on how much it will cost to replace. And also I talked to the dealer and he says it could be a CEM problem also.
Old Apr 13, 2008 | 08:58 PM
If it is the shunt and you fix it should be less than $100.00 I believe.
If Dealer fixes maybe $200.00 or so.
If it is the Cem and Dealer fixes I think around $1000.00.
Old Aug 13, 2008 | 10:29 PM
Ahmed's Avatar
Ok here we go again. After a few mounths my headlight problem is back again. Tech I know that you said the shunt might be burnt. Is the shunt the relay or are the two totally different things. Because the relay has been replaced.And how do I identify what the shunt is, like what does it look like. And how can I tell ifit is burnt if I find it. Do I have to replace the shunt or can I fix it. One night the headlignts dontwork and one night they work and the message dipped beam failer comes when the lights stop working.
Old Aug 15, 2008 | 12:40 PM
Ahmed's Avatar
Tech could you please reply to my post. Im in need of some help.
Thank You
Old Aug 15, 2008 | 07:03 PM
The shunt is in the main computer under the dash. It is a flat long black thing that is plugged into the computer. Also see link. http://dtmwerks.com/
Old Sep 24, 2008 | 06:38 PM
Ahmed's Avatar
Ok this is now the third time im having this Bulb Failer dipped beam problem. About just 3 weeks ago I took the car to the dealership and they told me that the shunt needed to replaced and after that the lights came back again and the headlights worked fine about for 2 weeks but now im having the same problem again. The lights sometimes work and they sometimes dont work. I know back in March of this year I had to replace the resister at the dealership and I also replaced the headlights and after that I had to replace something called a relay. Is it possible that the shunt can go back in just two weeks or is someting elese the problem like a bad CEM. I will be going back to the dealer this Saterday hoping it does not turn out to be a costly problem like a bad CEM. Can the CEM be cleaned.
Old Sep 24, 2008 | 07:14 PM
The CEM might be bad depending on how bad the old shunt was burned/melted.
cioara
1998-2000 model year V70
Sep 24, 2014 07:25 AM
techvolvo
Feb 2, 2008 12:39 PM
crystalfleet
Jan 16, 2008 07:30 PM
940Tgrl
Nov 28, 2007 08:24 AM
JimKW
Forum Issues
14
Sep 11, 2007 05:21 AM
