having trouble with oil filter cover
Old Nov 21, 2017 | 03:47 AM
gregs80's Avatar
Default having trouble with oil filter cover
had my exhaust fix over the week end and tech told me that my oil filter is leaking.
I found a 86mm 16 flute socket for the oil filter cover but it does not work,it keeps slipping on cover,do i have the right size.
2003 s80=t6\2.9
Old Nov 21, 2017 | 11:36 PM
thommykent's Avatar
Get a big pair of Channel Lock pliers
Old Nov 22, 2017 | 01:22 AM
gregs80's Avatar
very hard to reach it
Old Nov 22, 2017 | 08:29 AM
thommykent's Avatar
It can be done and you have no choice. Or get a really good removal tool made of cast aluminum.Sheet metal or plastic ones will not work if it`s on that tight as you found out.
Old Dec 10, 2017 | 02:36 AM
gregs80's Avatar
well I had my oil changed and it still leaks bad dont know were it is coming from.
any body have trouble with the front seal leaking.
Andrew Fritz
Jan 10, 2016 06:44 PM
cordoba
Sep 21, 2010 08:36 PM
KeithS60&V70T5
May 6, 2010 12:11 PM
DJRUZERS6
Oct 6, 2008 09:23 AM
foker500
Aug 3, 2007 09:53 AM
