Head lamp
Old May 13, 2009 | 06:55 PM
BassPlyr's Avatar
Red face Head lamp
I was replacing a low beam. when I attached the plastic housing to the bulb the plastic housing disentegrated. Does it need to be replaced or can the plugs be used w/out the casing.
Old May 13, 2009 | 07:46 PM
Johnny Mullet's Avatar
You can use the plugs without the casing temporarily, but it would be best to get a new connector wired in. Be careful none of them touch each other.
Old May 14, 2009 | 09:01 AM
Blownby's Avatar
Its 5 bucks at the dealer.Common problem.
part #8678122
Old May 26, 2009 | 08:46 PM
vikingpwr's Avatar
Just had the exact same thing happen to my s80/2003.Low beam went out,bought a new one,was told(do not touch the light bulb)..oil from your fingers will decrease the life of the bulb and the connector totally crumbled to pieces.Cost me about $75 to change it at a repair shop...guess very cheap plastic connectors...Glad to hear it's common and not just me..good luck and take care...!!!
noruckus
Mar 7, 2015 06:26 AM
ikey
Aug 14, 2009 05:15 PM
mjnajjar
Jan 6, 2009 06:42 PM
johnnybravo
Engine & Internal
Apr 5, 2006 12:52 AM
mdp61377
Jun 23, 2005 02:13 PM
