Headlight Bulb Replacement
Old Oct 15, 2007 | 10:49 AM
mrmullin's Avatar
Default Headlight Bulb Replacement
Hello,
This should be an easy question but I couldn't find it anywhere:
How doyou change the headlightbulbs on Volvo S80's?
I'm not sure what year, but I don't think the car has HIDs. It's a lowbeam. Do you have to take anything special off, move the battery or anything around first?
I'm expecting it to be an easy job but I figured I'd check first; it's for a friends car, so I won't have a lot of time to mess with it.
Thanks in advance for your help
Old Oct 15, 2007 | 06:29 PM
Default RE: Headlight Bulb Replacement
Look for a round plastic cover on the back of the headlight. Turn it to remove it.
Then unplug the bulb and unlatch the catch and replace the bulb.
Old Oct 16, 2007 | 10:03 AM
mrmullin's Avatar
Ok, thanks for your response
I was wondering, is it a pretty standard halogen bulb replacement, like on mid 90's VW Jettas etc.? Just turn the lock ring, pull out the bulb, unplug, plug in the new one insert and re-lock with the lock ring?
I'm most familiar with VWs. I know some of the newer VWs and other cars the designs got a little more complicated.
Thanks again
Old Oct 16, 2007 | 05:34 PM
They have a metal catch that folds over and lock. Kind of like aftermarket foglights.
The bulbs should be H-7 bulbs.
Old Oct 17, 2007 | 08:50 AM
mrmullin's Avatar
Ok, thanks very much.
Old Oct 18, 2007 | 10:57 AM
diehardgator1's Avatar
just replaced my right low beam and it was not a very big job to do watch out for the clip my fell off and I had a hard time finding it
Old Oct 18, 2007 | 05:01 PM
Finklespuss's Avatar
Hi, mrmullin.
I have a 2004 S80, and when I lost a H/L bulb, I simply couldn't fathom out how to replace it, and in the end I had to takeit into the Dealer. It's virtually impossible for the average owner,as the front bumper has to be detached, and there's NO WAY that one can get their hand at the unit from inside the engine bay. Was done immediately,happily, and free of charge by the Dealer, who told me that modern bulbs weren't designed to cope with the constant filling-jarring shocks of going over interminable speed bumps, and the filaments simply give up the ghost. Now, I go over speed bumpsin the manner thatthey are designed to make me!!!!!
sdl92
Nov 2, 2012 01:21 PM
Kiss4aFrog
Jan 19, 2012 12:54 PM
Tango
Feb 15, 2010 03:31 PM
MaxBoost13brx
Feb 16, 2009 09:07 PM
xxgolfpro
Nov 8, 2008 09:21 AM
