headlight removal
Old Mar 16, 2008 | 02:20 AM
yu21's Avatar
Default headlight removal
does anyone know how to remove the headlights on 1999 s80??
I've heard that i need to remove the front bumper as well
a diagram of the removal would be greatly appreciated
thanks
Old Mar 16, 2008 | 02:42 AM
mkelly85's Avatar
Default RE: headlight removal
There's a good explanation of how to do this already on this board, but no pics.
You have to remove the rivets to the wheelwell to get the bumper off; I tried not doing this and it just doesn't work. Have a Torx T-25 socket handy. Remove plastic rivets from top of bumper. You need an 8mm socket to remove the headlight wiper. I use a small ratchet, it's a tight squeeze. Remove bolts underneath bumper. Once you're able to slide the bumper forward and down, you'll see two other bolts that come out. I'm sure I'm missing something, but those are the main points.
If you replace the headlight, I'd recommend removing the side lamp and make sure the two interlock. The Taiwan parts are not an exact fit and you might need to trim the plastic where the two lamps fit together. Easier to do that off the car than on. Trust me, I know.
Old Mar 16, 2008 | 09:42 PM
yu21's Avatar
wow thank you so much for the explanation!!!!!!!
Old Mar 22, 2008 | 04:55 AM
dkvcopy's Avatar
ORIGINAL: yu21
thanks
Hey yu21,
Check out this site for headlights removal (includes with diagram of removal & installing a siren)...hope this helps.
http://vccs.volvocars.se/accessories...a-7e60a008779e
Cheers Mate !!!
Old Mar 24, 2008 | 04:37 PM
yu21's Avatar
wow that was exactly what i needed thanks!!!!!!!
Adrenalin540
Dec 12, 2008 10:42 PM
dpallen
Mar 15, 2008 04:57 PM
LokiLab
Jul 2, 2007 05:28 PM
340whpGTi
May 1, 2006 08:48 PM
banani
Sep 21, 2005 10:19 PM
