heater core
Old Aug 19, 2012 | 04:37 PM
robertcoyle's Avatar
Default heater core
how hard is it to replace heatercore in 2000 S80
Old Aug 21, 2012 | 04:40 AM
majorcode's Avatar
Hi,
What is the reason to change? Leaked heater core does not need to change always.
if the leaking is on the driver side then the only o rings need to be change if the on the passenger side then it need to be replaced.
It is quit a messy job, I recommend get it done by professional.
And if you are not living in cold area then block the pipes from back of the engine compartment (Like I did) and spent zero
Old Oct 14, 2012 | 01:22 PM
speedracersworld's Avatar
Thanks for the "O-ring" info I'll check it out. Was expecting it to be a heater core replacement. I was getting coolant on the drivers side carpet. Will update on the findings and resolution.
ycartf
May 6, 2013 11:19 AM
netconcepts
Jul 15, 2008 07:14 AM
Awespishus
Aug 9, 2007 04:49 PM
haydenm315
Oct 18, 2006 11:08 AM
azeezn
Dec 12, 2005 10:50 PM
