Help! 1999 S80 drivers side mirror plug swap???
Old Mar 6, 2016 | 04:51 PM
MrFoogie's Avatar
Exclamation Help! 1999 S80 drivers side mirror plug swap???
I recently purchased a 1999 S80, and the previous owner had had the driver's mirror shattered in a parking lot or something like that. He ordered a replacement for me in the right color and everything, but it has a green 16 pin plug whereas mine has a grey 10 pin plug. Is there any way I can maybe snip off the one plug and swap in the other, or redneck it in some way to enable the functionality of the mirror? I have read that there is often temp sensors in the mirror that will screw with the climate control if they are not working properly, so I want to try to avoid this if at all possible. I have basic Neanderthal soldering skills and am not too good at interpreting wiring diagrams and such, but if a capable scienceman could please explain to me if this is possible and if so, how - that would be great!!
Attached Thumbnails Help! 1999 S80 drivers side mirror plug swap???-1457304216808.jpg   Help! 1999 S80 drivers side mirror plug swap???-1457304248964.jpg   Help! 1999 S80 drivers side mirror plug swap???-1457304266980.jpg   Help! 1999 S80 drivers side mirror plug swap???-1457304284903.jpg
Old Mar 24, 2016 | 08:34 PM
volvos80319's Avatar
the complexity of the mirror is what would make doing that nearly impossible.... sell the wrong mirror on cragslist and hit up a salvage yard.... If worst comes to worst you can color match the back plastic painted cover...
Old Nov 22, 2018 | 10:51 AM
Maartenvc's Avatar
I had the same problem, I have an S80 from 2000 and bought a mirror from 1999. My mirror had a 16-pin green connector and the one that I bought a 10-pin grey connector. I took of the mirror glas and put in the motor of my old mirror (don't know if it's necessary), and soldered the green connector to the new mirror like this.
Dee
Nov 14, 2023 12:15 AM
taz01201
Sep 28, 2016 11:39 AM
nbender
Dec 17, 2010 05:03 PM
draco3
Sep 23, 2008 10:00 PM
lotusing
Feb 10, 2007 10:20 AM
