HELP! Please - Hydraulic Shift Solenoid (New Transmission?)
Old Dec 10, 2008 | 05:26 PM
calipryncess's Avatar
Default HELP! Please - Hydraulic Shift Solenoid (New Transmission?)
I have a 2000 S80 T-6 that I bought in August, 1999. I have coddled this car - doing every service required and some. She has less than 90K miles (I think around 88 - and the first 75K was mostly highway miles). Yesterday, it seemed a little bit weird - was skipping gears, struggling to get up a hill. I started to drive it to my local dealership when the URGENT Service Transmission Soon light came on.
The dealer says I have an internal fault - the hydraulic shift solenoid is bad - and therefore have to replace the WHOLE transmission. They told me it would cost $4900.
I just had the transmission serviced and flushed in July.
ANY advice you can give me would be great help. I am (was?) a Volvo for Life owner. My first was a 1986 240 DL and I was gearing up to buy my third next year. I called Volvo and they said they don't know of any issues with our transmissions, but the forums here tell me otherwise.
Old Dec 10, 2008 | 06:07 PM
Default RE: HELP! Please - Hydraulic Shift Solenoid (New Transmission?)
Did they give you a copy of the codes they pulled?
A solenoid can be replaced. Volvo won't do it but it can be done.
Old Dec 10, 2008 | 06:16 PM
Ahmed's Avatar
The 99-01 S80 GMtransmissions are known to have problems. They are garbage in my opinion. I had to have my transmission replaced at a cost of $3500 plus tax at a volvo dealer at 114k miles back in the summer of 07. $4900 is way to much. Is that including tax or no. I had mine replaced at the dealer in Columbus Ohio.
Old Dec 11, 2008 | 12:20 PM
I just e-mailed them asking for the Codes, and will post as soon as I have them.
The $4900 is parts, labor and tax.
The independent Volvo mechanic I spoke with also told me that the part cannot be fixed or replaced and I needed to get a new transmission.
My car is only worth $6500 and this is just traumatising - financially, and emotionally (I love my Volvo!)
Thanks for the replies. Will update as soon as I have the Codes, etc.
Old Dec 11, 2008 | 02:32 PM
Thanks once again for the replies. This is what the Volvo dealership told me the codes were:
It pulled a code TCM-000c=Shift solenoid s2 hydraulic fault.
Old Dec 11, 2008 | 02:39 PM
That solenoid should be able to be replaced.
It is kind of a pain but I believe it can be replaced.
I will look for the part# as well but it might take me till tomorrow to get it.
Old Dec 11, 2008 | 03:48 PM
Tomorrow is okay. I have arranged with the dealership to keep the car there until tomorrow afternoon. Thanks so much for all the help and suggestions.
Is there a site I can find recommended shops and/or mechanics?
Two Volvo dealerships (one in Southern California - very large and reputable - and one a little further North) told me that I had to get a new transmission. An independent Volvo mechanic in Southern California also told me the same. So not sure who can do this job for me!
Thanks - once again - for all the help and suggestions.
Old Dec 12, 2008 | 10:12 PM
Sowhat's the difference between a remanufactured or a rebuilt or a used transmission. I am getting more and more confused every day. AndI amstuck in a rental car until I get this fixed.
I guess there isno such thing as a "new" transmission.
Old Dec 13, 2008 | 07:10 AM
A rebuild and a reman are pretty much the same exact thing.
I will have the other info shortly.
Old Dec 13, 2008 | 08:42 AM
9480636 should be the part number you need. But to be 100% sure I would need the last 6 of your Vin#.
The transmission will have to be dropped down most of the way and the side cover will have to be removed to install it.
I had posted the instructions on here before but cannot find them.
Old Dec 13, 2008 | 06:24 PM
gordon368's Avatar
get it rebuilt from Aamco I just got mine its running solid and shifting like no tommorow ...
Old Dec 13, 2008 | 09:09 PM
Thank you for your help. I picked it up from the dealership and took it to a transmission shop. He said the part is replaceable. I am greatful to all of you - especially you 'tech' for all your help.
Old Dec 13, 2008 | 09:54 PM
Glad I could help you out.
Old Apr 15, 2009 | 02:55 AM
snkpkp's Avatar
OK slowing down in the motor way, while car slowing down transmission slams on me and then reduced power with traction control light on and CEL , took to service center I get TCM 0115 error code Transmission Solenoid S Hydraulic fault. Service guy is not VOLVO so cant say what parts i need... I hope you know what it is Tech?
850v
Mar 10, 2013 10:48 AM
ScottyJ
Aug 17, 2012 02:19 AM
scorpius
Jan 5, 2012 04:59 PM
rrc1960
Mar 30, 2008 11:22 AM
gooproduct
Jan 29, 2008 08:29 AM
