HELP.. transmission? MAF sensor? What can it be
Old Jul 5, 2013 | 11:11 AM
ivanovich's Avatar
Default HELP.. transmission? MAF sensor? What can it be
2001 S80 t6. the car sounds like it is in neutral (wont drive) after running for a few minutes. if i let the car sit for a sec then crank it up it will drive for a few miles then it won't drive, just rev up. please help somebody
Old Jul 5, 2013 | 06:48 PM
sneezer's Avatar
trans. same thing happend to me. 2004 s80 t6. dont bring to ammco transmission they will charge u $3,500.00 to get it rebuilt. any small trans shop will do for less. and not over fill your trans like they did to me they almost ruined it.
Old Jul 6, 2013 | 11:30 AM
torontos80t62000's Avatar
That's hard on the ears...that's the tranny.she be done. ..let us know what happens please were all here for you ..........dam it
Old Jul 6, 2013 | 12:02 PM
Do you have a check engine light on ??
Have you checked the fluid level and what does the fluid look like for color ??
Old Jul 7, 2013 | 10:27 AM
ivanovich's Avatar
When it first happened I had two codes, it gave me a incorrect forth gear ratio and some kind of, auxiliary output auxiliary input code. I cleared them a little while afterwards and they haven't popped up since. I checked the tranny fluid and it was a little high and very dark in color, like a dark dark maroon
yemmer
Sep 27, 2013 04:25 PM
Luca03
1998-2000 model year V70
May 21, 2013 12:19 PM
aleksey17
Dec 23, 2011 11:33 AM
Brennan.Messick
Sep 19, 2011 03:06 PM
02VolvoS40
Jul 16, 2010 08:12 PM
