Help: Window Problem
remove the door panel and with a light try to see what the problem might be, also try lubing the glass channels front and rear with soapy water from a spray bottle, slowly work the window either up or down , if you are not comfortable with doing this, dont try, but if you think you can handle this go for it, pulling the door panel is no big deal, best luck, rotgut.
I had the same problem with the drivers side window in my 2000 Volvo S80 as Ahmed did. It would only go down about 1/8 of the way. I took the door panel off and was able to get the window down by pushing on the window regulator arms. The window seemed to be binding on either the window blocks or window side channels. I ended up putting white lithium grease on the window blocks and vasoline on the glass side channels. The window is working fine now. Hopefully it will be a permanent fix.
850GLTWAGON
11-21-2008 04:14 PM
