How long will it take and cost to change camshaft bearings?
Old Mar 25, 2011 | 02:25 PM
blueyedstriker1's Avatar
Default How long will it take and cost to change camshaft bearings?
I am looking to buy a 99 volvo s80 but there is a problem. The guy says that it will need the camshaft to be replaced so I wanted to know how long that would take and how much it would cost
Old Mar 25, 2011 | 05:59 PM
Call a local repair shop. Prices change drastically depending on if the shop really wants to do it or not. Example, my shop will do it for $1,600, my other shop will change $2,800 because they really do not want to do it. The local dealer here may charge $3,700. You really need to check with who will be doing the work. I can tell you $1,600 and you it might cost you $2,000 to get your car here to get it done.
How much do they want for the car? How many other problems does it have?
Old Mar 25, 2011 | 06:00 PM
Just thought about your question and my response. Here is my new response... RUN!!!
Old Mar 25, 2011 | 07:30 PM
they want 1000 and it also needs a driversd side window motor.
Why run? Would it be a nightmare to get into?
Old Mar 25, 2011 | 08:42 PM
NoLifeTilBoost's Avatar
Cams dont just magically go wrong. To me it says oil starvation\pressure loss. Don't walk, RUN away, even if it is free. Run because S80s get expensive to repair real fast even if you are DIYing it. Start with one thats been maintained well, otherwise, honestly, dont bother yourself. If you want a volvo fixxerupper, get a 98 or older.
https://volvoforums.com/forum/volvo-...-%24500-51042/
Old Mar 26, 2011 | 12:00 PM
kory2000pr's Avatar
First, there is no bearings on the s80 camshaft. Second,It will take about 2 hours top to replace a camshaft. Third,Make sure that the oil passsages leading to the camshaft are not clogged.
Old Mar 26, 2011 | 11:07 PM
By the same logic theres no bearings on the bottom end of the connecting rods either. There are bearings, just not roller bearings.
Old Mar 27, 2011 | 07:34 AM
The Cam bearings are part of the head and cam cover. If it needs new cam bearings you need a new head.
Old Mar 28, 2011 | 12:39 PM
kory2000pr's Avatar
Thank you!
nmikmik
May 26, 2013 04:26 AM
Greener
Canada, Over Seas & Elsewhere
Dec 11, 2012 11:24 PM
FreddipiXC90
May 31, 2011 07:10 PM
diehardgator1
Mar 19, 2007 08:25 PM
