How this sensor named in English?
Old Oct 10, 2007 | 05:23 PM
Fikus's Avatar
Default How this sensor named in English?
hi.I have a problem with air .How this part calling in English?it must be replaced or i can clean this sensor?
Old Oct 10, 2007 | 05:40 PM
E_S80's Avatar
Default RE: How this sensor named in English?
It's called the Mass Air Flow (MAF) Sensor.
What are your problems with it? Can anyone else answer his question about replacing it/fixing it?
Old Oct 10, 2007 | 06:29 PM
Fikus's Avatar
the problem is that sometimes then i'm pushing the gas pedal ,the car doesn't response for some seconds.and i think that not enough air.may be
Old Oct 10, 2007 | 08:36 PM
01_fast_ride's Avatar
You can remove the MAF by undoing the 2 screws and then clean it. I did mine on my S60 a few months ago. Brake Cleaner may be too harsh(?) so I picked up some MAF-safe cleaner. You can find it in your local parts store for $4-5. Spray a generous amount on the sensor tip and allow it to air dry. Put it back in and you should be good for another year or two.
Old Oct 13, 2007 | 09:49 AM
Fikus's Avatar
ORIGINAL: 01_fast_ride
Thanks! i will try it.
Fikus
Aug 22, 2021 12:47 AM
v70t570
Jul 13, 2011 04:26 PM
froggie
Jun 21, 2011 10:12 PM
serega78
Dec 7, 2010 02:01 PM
hmsggg
Mar 26, 2010 04:51 PM
