Ignition lock cylindar
Old Oct 7, 2007 | 06:27 PM
99t6guy's Avatar
Default Ignition lock cylindar
Yesterday I went to start my '99 T6 and the key would just spin around and around. Finally after jiggling the steering wheel, playing with the key & praying, it would finally engage to the first position, then after more of the former, the second, and finally I got the car started. This is now routine every time I try to start the car. Also, I have noticed that the keyless entry has been acting goofy where the car won't lock until I get back in the car and start it, shut it off and then it will lock. Now the trunk release button doesn't work but the car will lock & unlock. Is this possibly related or just coincidence? I would rather not pay $200 for a new ignition lock if it just needs a $2 battery for the remote.
Thanks.
Old Oct 7, 2007 | 07:30 PM
Default RE: Ignition lock cylindar
Sorry but you have a bad lock cylinder.
The others is another problem.
Old Oct 8, 2007 | 09:08 AM
99t6guy's Avatar
That's what I thought. OK, now how do you repalce the lock cylinder? Should I replace the ignition switch while I'm at it? WIll any of this require reprograming my key? Thanks in advance.
Old Oct 11, 2007 | 05:37 PM
It will not require reprogramming the key.
The electrical part of the switches hold up pretty good.
It is best to remove the entire column to replace it.
It is pretty easy to get out.
crgolf
Feb 10, 2013 12:43 PM
NurseDave
Mar 30, 2012 01:54 PM
DaveV70
Jul 9, 2009 06:21 PM
cganotisi
Sep 22, 2006 01:20 AM
