Installation of GPS Car Tracker
Old Nov 2, 2013 | 09:47 PM
Dreamweaver's Avatar
Default Installation of GPS Car Tracker
Need to install a GPS tracker which requires:
1. Connecting to ignition, 12v power, and ground
2. Placement under dash as close to windshield as possible.
Any help in how to best connect to ignition and how to place under dash would be appreciated.
Old Nov 3, 2013 | 08:15 AM
Disco2's Avatar
Don't know what year you have but on my 99, I would remove that grille cover on the top-center of the dash and install it beneath the dash (that's close to the windshield) and hook the power supply to the fuse panel (#19 says "spare 30amp supply"... I'm sure there's some that are constant and switched) Finding a ground shouldn't be hard.
Old Nov 3, 2013 | 08:24 AM
Thanks for the reply. Mine is a 2002 S-80.
The grill on the top is just a cloth-covered piece of plastic. My daughter has the car right now so I can't look at it, and I can't remember what's under it, but I believe it's a speaker??? That being the case it wouldn't fit there.
The power it needs to connect to is 12v... is that 30 amp 12v?
Also, any ideas on how to access the ignition wire to connect to?
Old Nov 3, 2013 | 12:57 PM
Disco2's Avatar
I'm curious so I took my grille cover off. There's nothing under there... no connectors.. nothing. The only thing I see is there's a wire that connects to one of the tabs for the cover (???) It looks like there's some room in there.
Fuse #19 (spare) is a constant 12 volts. As for the ignition, I cant help you there. Maybe look for a fuse that has power when the ignition is on. I've never been one for cutting into ignition switch wires on newer cars.
Old Nov 3, 2013 | 07:29 PM
Thanks so much for the response. I got hte car back a few minutes ago so I'm gonna dig into it and see what I can find.
Now.... where did I put that hammer?
skying002
Mar 17, 2014 09:33 AM
skying11
Dec 6, 2013 02:26 AM
volvoftw
Nov 13, 2013 04:07 AM
AlanS
Nov 21, 2010 07:08 AM
joshconstipate
Mar 28, 2008 11:39 AM
