Itake cam TDC
Old Mar 24, 2011 | 12:27 PM
kory2000pr's Avatar
Default Itake cam TDC
I just bought a 2000 t6. I already replaced all the intake valves due to a tensioner failure.
The previous owner removed the intake cam gear both didn't make any marks.
Can somebody tell me in which direction the lobe needs to point in reference to the tdc mark? I just needed for the intake cam.
Thank you.
Old Mar 25, 2011 | 08:53 PM
NoLifeTilBoost's Avatar
First things first, just to be clear. It is not set at TDC, it is set just before it. If your crank marks line up then you are good, just understand that this is not TDC.
You need to set the cams on the rear first. When you look at the rear of the cam, the groove on it should be parallel to the seam of the head. The groove on the intake cam should be above its centerline and the groove on the exhaust cam should be below its centerline.
Are you familiar with setting the VVT on the exhaust?
Old Mar 26, 2011 | 10:51 AM
kory2000pr's Avatar
Thanks for the help. I already started the car.But like you mention the part that threw me off is that the crank mark is not really at TDC.
predxen
Dec 8, 2012 12:56 AM
redbottle
May 15, 2011 11:24 AM
neal289
May 9, 2010 12:37 AM
Crate45
Jul 7, 2008 10:34 PM
Carbuff
May 19, 2005 04:44 PM
