Just bought a 2001 Volvo S80 2.9
Old May 19, 2020 | 08:05 PM
mmfc77's Avatar
Default Just bought a 2001 Volvo S80 2.9
hello Everybody
I just bought a 2001 Volvo s80 2.9 a week ago. It has 93000 miles on it. I was wondering how long its fuel pump is expected to last.
Thankyou
Old Jul 3, 2020 | 07:46 AM
Brian401's Avatar
My original fuel pump went out at about 100k - if you take it to a garage, make sure you bring it to someone who knows Volvos (no chain shops). It's a two-part pump system between split tanks with an access cap that requires a special tool... they all want to hack a home made tool to use, but it doesn't seem to seal quite right.
Old Jul 3, 2020 | 12:31 PM
My Volvo 850's pump lasted 200K miles... Usually when pumps start to fail they draw too much current which in turn can fry the FPR. You can have a shop test the current draw to see if you're pump is on the edge or solid but most people find out the pump is failing when the car randomly stalls or sets a CEL for a fuel pressure sensor issue.
Old Jul 3, 2020 | 02:48 PM
donf's Avatar
Why are you concerned about that particular component? To be frank, there are a lot of other parts on a 20 year old Volvo w/ 100,000 miles that are more likely to crap out before the fuel pump.
My experience - 1998 S70 never replaced the pump, had close to 3000,000. My S80, 100,000 and the pump is still pumping.
Any chance you can get records for the car? Unless they are obviously new I would start replacing vacuum lines, belts (etc), PCV, plugs, wires/coils, and oil, brake, trans, coolant, PS , fluids. All those are due/ past due.
Regardless, I hope you like your S80, fine cars.
pingpang
Jun 3, 2016 08:38 PM
fiat128
Apr 16, 2014 10:26 PM
jlused
Dec 26, 2011 08:50 PM
KSIMP88
Jun 18, 2011 02:31 PM
johnsain3
Jan 29, 2006 03:52 PM
