just when I thought I was in the clear...New Code
Old Sep 8, 2009 | 11:40 AM
gordon368's Avatar
Default just when I thought I was in the clear...New Code
So my Check engine comes on at a stop today, and I checked with my scanner and it told me the code "p1332". From what it says, "Manufacturer control Ingnition Failure or misfire". From what I can see is that this is related to the cam sensor/position? The timing belt has not been changed yet (105,532 miles on the car). I dont think it jumped a tooth, but it has seemed to slow down/clogged feeling in acceleration. I did change the spark plugs over 2 months ago with NGK's.
Where do I start? Im very new with cars..
Thank you for any help
Old Sep 9, 2009 | 07:40 AM
BILL_MCCASSEY's Avatar
P1332 points to CVVT solenoid. Possible causes for the code could be, cam sensor, defective reset valve, problem in the VVT unit or it jumped time. Low oil pressure or poor oil quality can also cause similar issues.
Good luck
Old Sep 9, 2009 | 08:42 AM
gordon368's Avatar
thank you
MC92
Dec 30, 2011 07:03 PM
DontaviousJones
Apr 5, 2011 10:26 AM
Squiggy
Nov 6, 2009 02:25 AM
groovypet22
Mar 26, 2008 02:42 PM
gordon368
Mar 19, 2006 09:43 PM
