Lowbeams come on at random
Old Mar 8, 2011 | 09:06 AM
debbo9905's Avatar
Exclamation Lowbeams come on at random
My lowbeams will just come on at random times of the day. I could be driving and they will come on. I go to leave for lunch and they are on. I check my car out when i get out to make sure everything is off and the lights arent on and when I go back they are on. Think it could be the fuse? I also have problems with the key when I put it in the ignition it won't turn then after a few tries it will turn.
Old Mar 8, 2011 | 09:01 PM
zacharyzoosh's Avatar
Has the vehicle ever been in any water damage situation?
Or have you put in an after market stereo?
Once I had an aftermarket stereo installed in a 97' Volvo, and after that all sorts of problems occured similar to your issues.
I took it back to the shop (which was an amature shop) and made them tinker around until it was better, But other strange electrical problems started cropping up after that a bit later too.
If you recently had anything done like that, you should probably take it back to the shop. Just an idea...
Old Mar 8, 2011 | 09:11 PM
jlewisinsyr's Avatar
To clarify, are your lamps coming on when you are driving/car running or even when the car is off?
Most S80s have Daytime Running Lights enabled, so your low beams should be on at all times (regardless of switch position - with the exception of parking lights only) when you are driving. My guess is the switch is failing or something is tripping it up.
Old Mar 9, 2011 | 06:11 AM
unirok's Avatar
My 2004 has an aftermarket stereo and does not have any problems like that?
Old Mar 9, 2011 | 12:52 PM
debbo9905's Avatar
jlewis- Yes sometimes the light will come on when i'm driving. Now I get out of the car check the lights to make sure they are off and then I go back and the low beams are on.
Zachary- I bought the car used so I dont know if it had water damage and no aftermarket stereo. I've had nothing done to it.
diplomat128
Jul 9, 2013 01:13 PM
JeremyR
Aug 3, 2006 05:36 PM
NintendomanX
Mar 29, 2005 12:30 AM
mozhan
Dec 1, 2004 06:38 PM
miami_twice
Dec 22, 2003 01:02 PM
