lower brake pedal after replacing front brakes
Old Feb 25, 2010 | 01:14 AM
99volvo's Avatar
Default lower brake pedal after replacing front brakes
Sooo....
i just replaced my front brakes on my S80 with cross-drilled rotors and Hawk performance pads, but after breaking in the brakes the pedal seemed to be lower than it was before i replaced the brakes.
talking with my friends i concluded i might have gotten air in the brake line, so i had it flushed and replaced with some new DOT 4- but it's not much better.
Any thoughts?
--99v.
Old Feb 25, 2010 | 07:11 AM
vegasjetskier's Avatar
Are you sure you put the springs back on correctly?
Old Feb 25, 2010 | 07:29 AM
air force rascal's Avatar
If your brakes feel spongee..then you probably still have Air in the lines...
Old Feb 26, 2010 | 02:35 AM
99volvo's Avatar
i had the brake fluid flushed, so i don't think there is still air in the lines is the problem. thats why i had the fluid flushed in the first place. :-/
the kicker here is,when i initially hit the brakes, the pedal seems to need to travel farther to start bringing the brakes on. but if i have my foot on the brakes, then lift just a little then step down harder again- the brakes grab like they used to with the power that it used to, and it stops like the volvo it is.... which has me really baffled.
Note:--- now when i say "lower" or "farther" i'm talking maybe a centimeter farther than normal, i remember when the car was new, and even right before the brakes needed to be changed, but it's not like the pedal goes to the floor before the brakes come on, it just seems to not grab as hard initially.
Old Feb 26, 2010 | 02:38 AM
99volvo's Avatar
sorry- i forgot to mention anything about this one, but i even checked that when i had them bleed the brakes, and everything seemed fine, and looked like it was right where it was supposed to be.
Old Feb 26, 2010 | 07:36 PM
Take the car out and safely activate the brakes hard enough to activate the ABS and see if it gets batter after that.
stop_at_willoughby
Mar 7, 2014 05:22 AM
Justinyoder
Oct 3, 2013 12:29 PM
daver
May 27, 2013 11:21 PM
cruzcountryxc70
Engine & Internal
Apr 28, 2008 05:42 PM
atwialt
Mar 20, 2008 08:00 PM
