nothing works
Old Sep 5, 2007 | 09:47 PM
danieln's Avatar
Default nothing works
2000 s80 2.9, everything below the stereo doesn't work ( a/c, seat heater, the orange light for the gear select, the light for the "W" switch, the buttin that drops the rear headrests, the button that unlocks the trunk, the dome lights that are button operated and the moon roof) i checked all the fuses and non of them are blow is there anybody on here that could help me out?
Old Sep 6, 2007 | 08:47 AM
JPN's Avatar
JPN
Default RE: nothing works
Check for loose/disconnected electrical connector.
JPN
Old Sep 6, 2007 | 01:18 PM
master_pre's Avatar
Possible software issue but that would be a massive failure! [:-]
Old Sep 6, 2007 | 05:39 PM
Did the battery go dead lately?
Old Sep 6, 2007 | 08:13 PM
danieln's Avatar
ORIGINAL: tech
it got replaced, does something have to be reset by the stealership?
Old Sep 6, 2007 | 09:00 PM
Usually if you lock and unlock the car with the key and remote it will reset.
Old Sep 6, 2007 | 11:21 PM
danieln's Avatar
ORIGINAL: tech
do the key and remote at the same time or one after the other in a sequence?
Old Sep 7, 2007 | 09:19 AM
danieln's Avatar
well, i tried locking and unlocking it with the remote and key, the moonroof and dome lights work, is there a sensor that could have gone out when thae battery was changed that hase something to do with that panel?
Old Sep 7, 2007 | 05:32 PM
The ECC might have just gone out.(burned up from the low voltage.)
See if you can find a shop near you that can read the codes in the systems on the car.
Old Jan 16, 2009 | 06:45 PM
elguzzy's Avatar
I just had the same thing happen with my Electronic Climate Control (ECC) module in my 2000 Volvo S80. I was just checking to see if I could get to the light bulbs in the back of the ECC since one of them burnt out. I first disconnect the negative terminal on my battery as I learned I should do from this Volvo Forum. I actually never disconnected the harnesses on the back of the ECC. The only thing I did was take out a light bulb and put it back in. I did have to turn the ECC upside down to get the bulb out. When I put everything back together, the overall ECC moduledidn't work (i.e., no heat, no AC, no fan, no heated seats, and none of the switches on bottom of the ECC work). I didn't think I pulled extensively on the wires leading to the harness when I turned the ECC unit upside down, but I still may have accidently disconnected an electrical connector in the harness, as tech notesabove that could happen. I don'tknow how I could offried the ECC module when I was working on it since I had thenegative battery terminal unhooked at the time.
Has anyone else experienced similar symptoms with their ECC module and if so, what was the fix? Thanks in advance.
blackbrick
2001-2013 model year V70
Aug 14, 2014 07:11 PM
adn258
Apr 24, 2011 06:45 PM
bubba240
Dec 22, 2009 08:44 AM
joepataydis
Feb 27, 2009 08:01 PM
crazynlazycolombian
Sep 27, 2006 04:18 PM
