overriding the gear lock mechanism ?
Old Jan 24, 2009 | 06:40 PM
liory1980's Avatar
Default overriding the gear lock mechanism ?
Hi,
a friend told me that someone tried to steal his Volvo S80 and failed cause 15 secs after starting the engine
and driving backward from his garage, the alarm system shut down the fuel pump and electricity and the car would not move.
then he told me in order to tow the car to the garage to fix it, they had to bring a lift and lift the front of the car in the air, cause since they couldn't use the ignition , they couldn't change the gear from Pto N, so they can push it back, so the tow car could tow.
my question is :
there is no override switch that can be used to override the gear lock in case something like that happen?
thanks,
lior
Old Jan 25, 2009 | 08:45 AM
Default RE: overriding the gear lock mechanism ?
If you disconnect the battery the shifter should come right out of park.
Old Jan 25, 2009 | 11:52 AM
liory1980's Avatar
Thanks.
parottthead
Feb 6, 2011 09:44 PM
I8ASaleen
Oct 12, 2010 03:30 PM
alkali2010
May 26, 2010 12:38 PM
98T5
Jun 2, 2008 06:15 AM
Mr. T
Jan 30, 2005 03:17 PM
