Please Help - Check Engine Light
Old Aug 3, 2008 | 07:36 PM
BassPlyr's Avatar
Default Please Help - Check Engine Light
I have a 2004 S80 with the check engine light on. Had it checked during a recent NC inspection at a non volvo tere store. The result was a statement that said (extremely small EVAP leak). It is not the gas cap. What would be the next few obvious things to check.
Old Aug 4, 2008 | 06:33 PM
Default RE: Please Help - Check Engine Light
Have you left the key on while getting gas at all?
Old Aug 5, 2008 | 06:33 AM
bigern45's Avatar
get a smoke machine and see if you have any small leaks. or u may not even have a leak. a sensor could be degraded and not reading right. or you could have fueled up with the car on. if it was me, id clear the code, find out how many drive cycles it takes to run that test, do it, and see if it comes back on. just make sure the cap is good, and its on tight.
Old Aug 7, 2008 | 07:11 AM
BassPlyr's Avatar
I have left the key in the ignition at times but never had the engine running. Somtimes I leave radio on for occupants, but rarely. Does the key need to be removed from the ignition?
Thanks
Old Aug 7, 2008 | 07:13 AM
BassPlyr's Avatar
I did reset the check engine light (had it done) and it took about 300 miles for it to come back on. That included highway and city driving.
Thanks
Old Aug 7, 2008 | 09:04 PM
bigern45's Avatar
and how do you know that your gas cap is properly functioning? did you have it tested, or have you replaced it with a brand new one?
Old Aug 9, 2008 | 12:25 PM
BassPlyr's Avatar
I did change the gas cap. After 3 fillups the light final;ly went off.
Thanks
BassPlyr
Old Aug 9, 2008 | 04:21 PM
bigern45's Avatar
so its fixed??
rocketarm09
Apr 7, 2012 02:33 PM
q2quest
May 23, 2009 06:35 PM
ErnstlS90
Oct 23, 2008 08:37 AM
akilic01
Apr 21, 2007 10:47 PM
