Radio Replacement
Old Nov 14, 2005 | 05:28 AM
josh_jmp's Avatar
Default Radio Replacement
Could someone please tell me how to remove the radio from a 2000 volvo S80. i've tried everything! Any help would be much appreciated.
Thank You
Old Nov 14, 2005 | 08:50 PM
Default RE: Radio Replacement
Remove the little PEN holder in front of the shifter.Under the A/C controls and switches. Then you can remove the 2 screws under the A/C controls. Lift from the bottom and pull from the top of the A/C controls and it should come out. It might give a little trouble sliding out. There is tabs on the top of the A/C control panel that lock top the bottom of the radio assembly. Once that is out then you will see the screws under the radio.Remove the 2 screws and it will come out.
Old Nov 8, 2008 | 09:31 PM
jwardmls's Avatar
here is a link to a step by step picture guide... it helped me with the 01 s80...
http://www.carstereohelp.com/stereoremovalVolvoS80.htm
Psaboic
Mar 31, 2008 10:52 PM
gus_dog
Sep 18, 2007 09:27 PM
cbgav
Sep 10, 2007 05:25 PM
