Replaced battery and now no sign of power anywhere
Old May 20, 2020 | 02:03 PM
KerryRisley's Avatar
Default Replaced battery and now no sign of power anywhere
i have a 2008 s80 and recently replaced the battery. After replacing the battery, i now have no power at all. interior lights/bells/dashlights do no come on. No sign of life. i checked all connections, fuses, had the battery tested (good battery), but i can get no sign of life. What should i check next?
Old May 20, 2020 | 06:47 PM
Assuming you connected it correctly next thing is to start probing with a volt meter. volts from battery post to battery post? volts when going from + battery post to chassis ground point? volts to the main fuse/relays? etc. Does anything come on that's not tied to the key?
cb1313
Dec 20, 2021 10:44 AM
Jdsikking
Mar 27, 2018 08:27 PM
Christian J. Carlander
Jul 19, 2016 09:48 AM
rberkley
Nov 11, 2009 04:17 PM
dcjcdc
Aug 7, 2008 01:27 PM
