Rubber squeaky from front???
Old Nov 9, 2011 | 02:30 AM
macplee's Avatar
Default Rubber squeaky from front???
My 2004 S80 recently started making this rubber squeaky sound 3 out of 5 times when I drive it.
Once the noise starts, it can heard while the car is in motion. I asked my wife to turn the steering wheel while the car was parked and I was outside looking, the sound was coming from front passenger wheel area.
I heard the noise when the steering wheel is turning, doesn't matter to which side it turns, but I am certain the noise is coming from front passenger wheel area. It will also make the noise when I press down on the front passenger side wheel area too.
Any clue?
Old Nov 11, 2011 | 05:14 PM
hughrhodes's Avatar
Sure it isnt the glove box? Its notorious for squeaking. May be the upper strut mount. The OEM ones fail rather quickly and make a racket.
Old Jul 28, 2012 | 01:47 PM
cartroadie's Avatar
Have a 2007 S80 with 27,000 miles on it. Just had the right rear wheel area start some loud squeaking which varies with the road surface and driving conditions. While parked, bouncing on the fender produces a similar squeak. Pulled the wheel, nothing obvious showing. Sprayed WD40 on all rubber and plastic. Seemed to quiet it for a few miles but returned louder and more persistent. Any ideas or suggestions? Don't want to start changing parts or take it to dealer w/out some idea of what the problem is.
Old Jul 28, 2012 | 02:35 PM
akabond's Avatar
hmmm could be the top strut mounting assemblies are bad. Also open the hood and then press again on the side and do you see anything abnormal?
firstvolvo
Apr 13, 2017 06:03 PM
johnwartr
May 17, 2013 08:58 PM
Sssnake
Jul 30, 2009 01:33 AM
S70turbo1999
Dec 20, 2005 11:11 PM
98v70
Jan 19, 2005 07:04 PM
