s80 has miss
Old Jan 29, 2008 | 04:22 PM
nitrodog's Avatar
Default s80 has miss
Is there a way to test indavidual coils?
or do I have a bad injector?
any Ideas on solving this miss would be great ...Thanks
Old Jan 29, 2008 | 05:25 PM
sophisticars's Avatar
Default RE: s80 has miss
Hi Nitrodog.
Do you have a warning on your onboard computer? If so it could be your coils.
Does it miss all the time or just under cetain revs?
Coilpacks can break down on certain revs so car may idle ok but not rev!
2 ways to test,
1) hook it up to engine diagnostic machine, if it is a coil pack it will tell you which one, if it is another electrical issue etc it will also tell you the fault.This is by far the best way of finding out and the safest!
2) if you don't have a machine and there is no message i would say it is highly unlikely that you have a coil down. However if it is you can take the cover of the top of the engine and by unplugging 1 coil at a time you will be able to tell which one is at fault e.g pull out coil 1 if the engine revs change then there is nothing wrong with that coil, plug back in 1 and unplug 2 carry on the process until you unplug a coil and the engine does not change tone, therfor that coil pack is not working! BE CAREFUL WITH COIL PACKS HIGH VOLTAGE!!!
Let me know how you get on or if the above doesn't fit it in with your problems.
Phil
Old Jan 30, 2008 | 09:04 AM
nitrodog's Avatar
thanks for the info, Im checkin in to whos has a diagnostics machine in my area
its hard to get to all the coil plugs with all the turbo plumbing , but a great idea
you can't feel the miss at idle . but its there all the time when you rev it
d33dvb
Jan 13, 2010 10:46 PM
mason0929
Nov 8, 2009 06:53 PM
trooperone
Mar 5, 2009 06:26 PM
pconfar
Dec 27, 2007 05:39 PM
aeabston
Jul 27, 2007 10:00 PM
