S80 leaking water from head liner
Old Jul 23, 2017 | 02:07 PM
wpascarelli's Avatar
Default S80 leaking water from head liner
Hello all,
I am new to this forum. I had a 1996 850 for many years and then in 2009 I got a 2007 S80.
Since I bought it, I have occasionally been having this issue. Id say between 1/3 and 1/2 of the times that I take it to a motorized automatic car wash, a lot of water starts leaking in from the front of the cabin lights assembly. This was not happening all the time but it was happening often enough to be annoying and I did not expect this from a newer Volvo.
Every few years while it is at the dealer for service I ask them and plead with them to try to figure out what the issue is. The dealer techs have tried several things and they cannot find what the cause of this could be or how to fix it.
I have also noticed recently this issue has happened a few times when it was raining out, which never happened before.
I am pretty upset that there is nothing that the Volvo techs could find. Has anyone ever heard of this problem before on their volvos or other cars and are there any recommendations on how to fix it?
Thanks.
Old Jul 26, 2017 | 09:28 AM
mojobaby27's Avatar
Do you have a sunroof? If this is the case sometimes the drains from the sunroof can get clogged, I had to use the compressor to blow down the holes in the track around the sunroof to clear them out. Since then no problems with water in the car.
Old Mar 27, 2022 | 11:48 AM
Kevin Whitton's Avatar
Originally Posted by wpascarelli
Hello all,
Thanks.
Over time the drain tube that runs down inside the a-pillar shrink pulling them out of the rubber elbow that leads the water out resulting in the water running in to the cabin. The elbow tube is located in the corners at the base of the windshield. The volvo techs should know this
H8ngy
Jan 1, 2023 11:06 PM
phobod1
Apr 29, 2021 07:12 AM
Tcraven92
Feb 8, 2020 10:54 AM
raptor1288
Jan 17, 2014 12:08 PM
Rafiolo
Dec 24, 2012 05:49 AM
