S80 water leak
Old Jan 13, 2014 | 04:30 PM
raptor1288's Avatar
Default S80 water leak
Hey guys, I originally posted this under specific car but got know response..anyone??
Suddenly noticed my passenger side floor was wet other day in rain storm. Actually could see two small trails of water running down inside molding from around about underneath corner of the dash. I pulled the SRS service cover off and saw droplets and it appeared the sound insulation was wet inside..any suggestions?
Sorry this is a 2008 S-80 3.2..base...wondering also if there is a way to find brake size..i bought the car used and time for service.
THANKS
Old Jan 14, 2014 | 06:15 AM
ibanez958's Avatar
the water is leaking from the sunroof drain. check the front sunroof drain if it is plugged then following the tube from both the a-pillar if they r fell off.
Old Jan 14, 2014 | 04:03 PM
raptor1288's Avatar
thanks..I see the drain, but how do i get to the tubes in the pillars? I have side air bags afraid to mess with it.
Old Jan 14, 2014 | 04:31 PM
Open the sun roof and look in the corner of the sunroof frame. You should see the tubes there. You can pour water in the tracks and see if it drains out the bottom of the car, if not, you will need to clear the drains.
I have also read of people having the window base cowling clogged with tree debris. When you open the hood, do you have a lot of tree trash built up on that plastic part at the base of the windshield?
Old Jan 14, 2014 | 04:59 PM
damien360's Avatar
Normally the elbow that is at the end of the drains gets clogged up or wears ways due to age causing water onto the floorboards. They should at the end up the drain hose just below the dash.
Old Jan 15, 2014 | 06:20 AM
ibanez958's Avatar
There r 2 ways u can do that. first by getting a cert. tech. to do it for u. or DIY but require some safety procedure when u r working around airbag. But if u r going to DIY u may want to disconnect the battery then wait at least 30 min. before u work on the airbag.
Old Jan 15, 2014 | 09:15 AM
damien360's Avatar
There is nothing to worry with that airbag, you're working around it but unless you're goings to give it pet nothing is going to happen because you don't have to disconnect it. Even if you diff have top disconnect it there's no need to remove the negative battery cable, to me it's a waste of time and an unneeded step.
Old Jan 15, 2014 | 03:52 PM
raptor1288's Avatar
Thanks guys..off the next few days and will take a look at your advice and let u know how I make out!!1
Old Jan 16, 2014 | 04:39 AM
KandiceWestbrooks's Avatar
i have juggled with it and at last arrived to none .. so in support of ur view
Tevida Price
Tevida Side Effects
Old Jan 16, 2014 | 09:27 AM
damien360's Avatar
Well I make money based on how fast I do the job, so the faster I get the job done the faster I can get to the next job. So when I say that it is a waste of my time it is exactly that, a waste of my time.
Old Jan 17, 2014 | 09:14 AM
ibanez958's Avatar
is just a safety procedure for people who never work around airbag system. In the dealer i won't even take the connector off to do that job. Not everyone in the forum have the same skill level.
Old Jan 17, 2014 | 12:08 PM
raptor1288's Avatar
Next question..need brakes..all the parts stores show 300, 316, 336MM for sizes so i called Volvo parts..they say mine has 16 inch..sooo American parts store use metric..Euro cars use American confused..lol..assuming I would get 300mm as they are smallest and other brakes sizes are 16.5 / 17.5 inch???
jdbs3
Nov 28, 2017 05:05 PM
s70_007
Dec 19, 2008 09:26 AM
flapper
Oct 22, 2007 05:56 PM
m1964
Sep 12, 2007 09:57 PM
mesaview
Nov 27, 2006 02:36 PM
