S80 motor swap into 850 GLT
Old Jul 6, 2007 | 06:42 PM
ProMischiefMaker's Avatar
Default S80 motor swap into 850 GLT
hello all,
I was curious as to if the S80 twin turbo motor would fit in a '97 850 GLT (turbo). I'm aware that there would be fabrication neccesary but I was wondering how much would actually be needed, or if the motor would bolt up to the 850 transmission at all. Any help on this subject would be extremely helpful, thank you.
-Sam
Old Jul 12, 2007 | 04:04 PM
S70driver's Avatar
Default RE: S80 motor swap into 850 GLT
This is a slow forum. VS is a fast moving forum.
1. The s80 motor will not bolt up to your 850 trans. That is just a given. Two totally different cars.
2. I'm sure there would need to be some fabrication to make it fit properly. How much fabrication I don't know.
3. Your 850 ecu is totally different then the s80 ecu. They are not swapable.
4. I suggest you get another T5 engine. You will know it will fit for one. Not to mention there are many more modifications out there for it.
Spalding
Jan 7, 2015 04:16 PM
VTBricked
Nov 6, 2012 07:43 PM
5cylinderkiller
Mar 27, 2011 09:24 PM
bsamole
Apr 26, 2009 06:27 AM
ProMischiefMaker
Jul 14, 2007 09:47 AM
