S80 Rear Caliper Removal (2008)
Old May 28, 2013 | 03:51 PM
tenui's Avatar
Default S80 Rear Caliper Removal (2008)
Is there a trick to being able to get an impact wrench or breaker bar with extension on the rear caliper mounting bolts? Do I need to remove the rear springs or strut/sway bar? Everything seems to be in the way. What I thought was going to be a quick job is turning into a multi-day experience.
Thanks!
-john
Old May 28, 2013 | 09:08 PM
ES6T's Avatar
Nothing else needs to be removed. I just use a long 3/8" ratchet and socket. Did you remove the caliper already? Once it is out of the way you have a little more room for the bracket bolts.
Old May 28, 2013 | 09:13 PM
tenui's Avatar
Its the rear caliper bolts I am trying to remove, not the slide pins. On the 2008, it looks like the slide pins stay in place and the caliper bolts are removed. There is not a lot of room.
Old May 29, 2013 | 07:47 AM
ES6T's Avatar
The slide pins stay in place but you should remove the 13mm bolts and remove the caliper. There's nothing tricky about removing the caliper or bracket.
Old Jun 9, 2013 | 08:56 PM
sunwise's Avatar
I have an 08 s80 and recently had 2 different mechanics tell me that the only way to get the calipers to open was to take the vehicle back to the dealer so they could hook it up to the computer - unfortunately for me the dealer was 45 minutes away. Probably won't be buying another Volvo.
Old Jun 10, 2013 | 08:17 AM
75ohm's Avatar
Auto parking brake?
I just did the rears on my wife's car; 2x15mm bolts on each caliper. I was able to easily put a wrench on the lower... and a socket for that matter... but without auto parking brake...
Old Jun 10, 2013 | 08:50 AM
ES6T's Avatar
There is a way around activating service mode for the parking brake. The motors come off the back of the caliper very easily.
Old Dec 26, 2013 | 08:20 PM
Rockyard's Avatar
On my s80 the caliper mounting bolts were extremely tiight. When I finally got them loose it looked as if someone had put locktight on them.Is that normal. When I replaced them I just tightened them as tightas I could.
Veronica Tumavicus
Nov 1, 2017 07:08 AM
whlaw@aol.com
Mar 30, 2010 02:10 AM
yank50
May 21, 2009 07:05 PM
KeitaS60R
Dec 16, 2008 04:46 PM
silverado102002
Jun 19, 2007 09:11 AM
