s80 remote lock issue
Old Jul 17, 2014 | 04:29 PM
taj59's Avatar
Default s80 remote lock issue
I posted this in general chat and got a lot of views but no replies...didn't realize I should have posted it here:
I feel like these problems are all related to a common cause, I could be wrong and it could just be a coincidence. My remote door lock fobs stopped working when not in use for a short time. I replaced battery but this did not help. The low tire pressure light also came on about this same time frame and will not go off. I've checked the tires every day. I also disconnected the negative terminal from the battery to see if everything would reset. The only thing this did was cause the automatic windows to stop working. If you put the emergency key in the door lock and unlock it, the fob will unlock the other doors. Also, after you've shut down the car it will work to lock and arm the car. you can actually cycle through the process and it works flawlessly. but after you go in the house for a little while and come back out, the fob doesn't work again. any ideas would be appreciated.
taj59
Jul 17, 2014 08:37 AM
schmuecker
May 19, 2011 06:45 PM
digimower
Aug 17, 2008 12:55 PM
Volvonut
Dec 22, 2006 02:02 PM
