S80 sunroof adjustment
Old Feb 25, 2010 | 09:35 PM
trooperone's Avatar
Talking S80 sunroof adjustment
I have adjusted sunroofs on 850's and S70's of ours before, but looking at our '01 S80, it appears that the mechanism is a bit different. Does anyone have any idea if they even CAN be adjusted? Ours is not leaking, but when you close the doors with the windows up, the air pressure makes the sunroof "jump" just a bit. It also seems to have a little bit of wind noise when driving at highway speeds.
Thanks for your advice!!
Old Feb 25, 2010 | 10:13 PM
Yes they can be adjusted. Once tilted up you need to pull the plastic piece from the glass to inside the car. But be careful because they always break apart. Once the plastic part is away you will see the screws.
Old Feb 26, 2010 | 09:56 AM
trooperone's Avatar
OK thanks!! That "accordian" plastic looks like it would break easily...yeesh! Oh well....
Old Feb 26, 2010 | 07:42 PM
Good luck!!
Old Feb 27, 2010 | 07:00 PM
scubatelco's Avatar
I removed the sunroof to replace the gluides on the sun screen. I used black window silicone to glue the edges together after the plastic accordian ripped. Worked great.
Old Mar 11, 2010 | 10:00 PM
PieceKeeper's Avatar
The sunroof on my '01 2.9L jumps too when i close the doors. I've remove the sunroof, inspected and put a lot of torque on the four torqx screws with no success of eliminating the jump when doors are closed.
________
Herbal vaporizer forum
Old Mar 11, 2010 | 10:12 PM
Did the metal support bars on the front and back of the glass fall off?
Old Mar 31, 2010 | 10:11 PM
andrei3333's Avatar
is there a slider when you undo the screws that you just move down and retighten the screws ?
how does one adjust it exactly ?
Old Apr 6, 2010 | 11:03 AM
contsi's Avatar
Mine did (the back one), Can that be glued back on? Any particular glue?
Thanks
Old Apr 6, 2010 | 07:21 PM
I have not seen any glue able to hold them back on.
Old Apr 29, 2010 | 11:40 AM
I've had mixed results with an epoxy formulation for glass - metal combinations. Bought the stuff at Home Depot. The expoxy seems to hold for about 9 months and then begins to loose its holding power.
________
TOYOTA SPECS
Old May 2, 2010 | 02:28 PM
chandler's Avatar
In addition to my other post, I went out and used your suggestions. Loosen up the torx screws, lift up on the glass and tighten them up. Worked great to seal mine. Now if I can just get the window to move, I'll be happy (ier). Checked fuses.
Old Dec 12, 2010 | 10:14 PM
shopower's Avatar
My sunroof seems to be falling down (inwards) at the back of the roof opening. Will these screw allow for this to be adjusted? after the adjustment should I run the SRM calibrating??
'99 Volvo S80 T6
louiebay
Apr 30, 2013 02:44 PM
740Guy
Oct 21, 2010 01:46 PM
740Guy
Oct 21, 2010 12:59 PM
nextproject
Nov 16, 2009 07:04 PM
dinopix
May 9, 2006 08:10 PM
