S80 T6 1998 GM gearbox stuck on 3rd
Old Oct 24, 2012 | 05:23 AM
Vytas's Avatar
Default S80 T6 1998 GM gearbox stuck on 3rd
Hello,
i just buy my first volvo s80 one month ago, its 1998.10 2.8 automatic with GM gearbox 200kw.
since i buy it i allready got message about the gearbox service it was sometimes stucking on the 3rd gear with S2 solenoid and RPM faults, ir was stucking on 3rd or skiping it at all. so i changed the gearbox from another T6 with same GM gearbox, and now i got incorrect gear ratio errors on 2,3,4 gears .i have tryed to change few gearbox computer but without luck, the owner of gearbox saying that it was working fine, and it really is. it shift very smoothly and without any hits. it only drops in safe mode when i am trying to keep stable speed from about 50-60km/h and get stuck in 3rd gear without any chance to switch in any other, i have to restart the car in order to get it working again. i believe this is the 3rd gearbox on this vehicle and canot slove the problem. i heard that the GM boxes is stronger then the aisin ones. i spend about 2k euros allready and still no luck!!! little bit details:
i connected vida dice and take it for a ride with RPM senosor graph on the screen one from engine and another signal from gearbox, so they are almost allways going at the same level and showing good information, since i get the error about the gearbox and stuck on 3rd gear the signal from gearbox RPM graph goes all the way up and stays on 6000rpm.if you need any other info from my diagnostics just ask. and please do not offer to change the gearbox becouse this is not the solution. any ideas?
vehicle cannot hold stable speed more then 50kmh when on any gear...puts in 3th and stuck on it.why!?all gears works perfect what is wrong with this car, nobody can find out...
Old Oct 24, 2012 | 01:24 PM
akabond's Avatar
this is THE NO1 problem found on older S80. sorry but just get it re-build trans or sell your car. it will cause more problems with major $$$
Old Oct 25, 2012 | 12:26 AM
Vytas's Avatar
ok.but why the gears are shifting perfecf ? its simply rpm signals grom tcm and ecm does not match in about 10%.and if i rebuild it how much is gona work for me then, one year?i am not gana sell the car i like it.i still have to drive with that faulty transmisio about 2k km i hope nothings gona hapen..
jnduke
Oct 8, 2010 09:17 PM
BLARCHITECT
Feb 25, 2010 11:02 AM
Kyla
Sep 29, 2008 07:35 PM
gratefulvolvo
Jan 3, 2008 08:28 PM
TedDansonMachine
Oct 5, 2004 10:15 PM
