s80 transmission
Old Dec 21, 2015 | 05:46 PM
alcaros888's Avatar
Default s80 transmission
I have a t6 2004 with automatic transmission of 4 gear ahead. Any one knows if I can upgrade this one to improve the performance, actually it makes from 0 to 100 kms in 13 seconds, and I think it has much to be with the gear box. A 2.9 lts bi turbo with this performance?
Old Dec 22, 2015 | 07:34 AM
VolvoS80User's Avatar
Hello, I know a decent amount about cars. If I were you I would upgrade the engine horsepower before you change the transmission. Sometimes, upgraded transmission that are fitted to stock engines will tear up you crankshaft and that would be bad.
Old Dec 22, 2015 | 05:51 PM
pkrface's Avatar
+1^^^
That trans is perfectly capable of handling more torque. Boost the engine to get the desired result.
Old Dec 23, 2015 | 09:44 PM
volvos80319's Avatar
that car should be able to do 0-60mph in 6 seconds, if yours cant get close you have issues to address with the car, on putting a different transmission in it, not oe will be nearly impossible let alone expensive and labor intesive, it takes 13 hours to pull one out if your a one man crew and know what you are doing, as to modifying it for performance, again goodluck, if you want a faster car from volvo buy an s60r, chances are you will screw up the car badly trying to replace factory settings
Old Dec 23, 2015 | 10:41 PM
ES6T's Avatar
The T6 trans is junk. I wouldn't push it.
Old Dec 23, 2015 | 11:22 PM
I think the main problem with the trans is it was never a good fit for the job, its supposed to be in a grand am not a turbo volvo... to much stress on it... these cars would be great with a six speed
Old Dec 24, 2015 | 10:32 AM
ES6T's Avatar
It does decent in the S80. Not so well in the XC90. I don't think I'd ever call a P2 T6 S80 "great".
Old Dec 24, 2015 | 02:31 PM
pkrface's Avatar
Does it not have the GM 4T65E?
mason3325
Dec 22, 2021 12:51 PM
jeffrisley
Jun 14, 2015 01:48 PM
robs80
Dec 31, 2004 04:18 PM
