Seriously bad oil leak
Old May 30, 2014 | 06:21 PM
astouffer's Avatar
Default Seriously bad oil leak
On my 1999 S80 T6 I just replaced the camshaft seals and timing belt because oil was leaking all over the timing belt cover. No leaks there anymore. I also replaced the flame trap and dipstick seal although upon inspection all the engine ports were clear.
So now after driving for a while there is a steady drip of oil coming right down by the lower motor mount between the transmission and oil pan. It leaves a large puddle after a day at work and then a steady trail while pulling into the driveway. Any ideas what could be leaking down there besides the rear main seal? I lose like two quarts a week.
Old May 31, 2014 | 12:41 AM
difflock54's Avatar
Did you replace the rear camshaft seals also? Or only the frontside.
Could be a leaking seal tracking down to underside of transmission bellhousing area near the weephole.
Oil from the weephole itself is likely the RMS.
Old May 31, 2014 | 03:12 PM
astouffer's Avatar
Oh man thanks for suggesting this. Earlier today I was browsing craigslist and nearly responded to someone who bought Volvos.
I only replaced the front seals by the timing belt and ordered that pound in metal cap but never installed it. I left it off in case of having to redo the timing procedure. Well when I removed the old one some oil did dribble out but it wasn't filled up or anything but now it looks like without that cap oil was almost spraying out! Oil is all over that side of the engine. I'm going to order new seals for that side and another metal cap.
Quick edit. Is that metal cap the seal itself?
Old May 31, 2014 | 06:18 PM
difflock54's Avatar
Its only a cover cap. Keeps dirt etc out.
Blowing seals can be caused by your PCV system requiring replacement or servicing.
Do a glove test over your oil filler opening to see if it inflates.That indicates excessive crankcase pressure which loads up the seals and they leak oil.
It should suck the glove inwards with a vacuum if its healthy.
Old Jun 1, 2014 | 11:38 AM
astouffer's Avatar
The PCV system is good. When I took it all apart everything was clear.
FCP is showing one part number for rear cam seals. Volvo S80 Camshaft Seal Parts | FCP Euro
So its used on both cams?
Vinnyobri
Aug 22, 2015 08:13 PM
wvcycling
Jan 14, 2013 01:07 AM
Ahmed
Oct 9, 2012 11:51 PM
apfurste
Jul 2, 2009 04:47 AM
JRXC70
Feb 29, 2008 07:26 AM
