serpentine belt removal
Old Sep 5, 2008 | 05:14 PM
computowne's Avatar
Default serpentine belt removal
Hello, I have a problem,I keep getting battery low voltage when I sit at a stop light or use the ac. After driving about 1 mile message clears . I have changed the battery and still recieve the message. I was going to change alternater but can not figure out how to remove the s belt wheel tensioner, feels smooth no place to put a socket and scew to back off tensioner. How do you back it off? It's a 2002 s 80 2.9. Thank you
Old Sep 5, 2008 | 06:12 PM
vegasjetskier's Avatar
Default RE: serpentine belt removal
I think there might be a plastic cap on the pulley that you need to pry off with a screwdriver to access the bolt. Here's a tutorial for S70, yours is probably similar: http://volvospeed.com/Repair/sbelt70.php
Old Sep 5, 2008 | 10:18 PM
Thats how I do it. But also if you look closely with a mirror there is a hole where you would install a torxes socket but it is a big one like a torxes 50 or 55. Thats why I pop the cover off and use a 14 MM wrench.
Tim Sway
2001-2013 model year V70
Apr 12, 2013 10:43 PM
iscwebe
Feb 9, 2010 12:50 AM
rmmagow
Dec 20, 2008 08:53 PM
rationull
Aug 15, 2007 06:12 PM
toine910
May 14, 2004 08:57 PM
