View Poll Results: Should I switch to synthetic?
Yes
66.67%
No
33.33%
Switch to a blend of both.
0%
Voters: 9. You may not vote on this poll
Should I Switch to Synthetic? 103k Miles.
Old Oct 27, 2010 | 03:33 PM
MrJARichard's Avatar
Arrow Should I Switch to Synthetic? 103k Miles.
So I purchased a S80 in June and it's well overdue for an oil change. Currently, the oil being used is conventional (I think, nothing was said differently), I'd like to switch to synthetic though. Is this a good move with 103k miles on it? It's a 2001. I also noticed that I had to top off my oil recently, so I'm not sure if there's a leak or if the engine is burning it or if it's because I'm reaching 5,000 miles without a change.
Any suggestions, past experiences is much appreciated.
Old Oct 27, 2010 | 09:00 PM
commops106's Avatar
i would switch to blend run a 1000 miles through then change oil use full syn for 1000 miles then change oil again then change oil with syn and go to 5000
Old Oct 28, 2010 | 09:18 AM
donf's Avatar
I'm a big synth fan. Being lazy, I would just pour some Sea foam in the crank case hop on the highway in 3rd gear for 1 minute(if you have a turbo) then drain and fill with synth and go for 5000K. That stuff is the automotive equivalent of a bran flake and prune juice breakfast.
Old Oct 28, 2010 | 08:22 PM
jlewisinsyr's Avatar
No...at that point in the game I'd stick with what was used.
Old Oct 28, 2010 | 09:59 PM
If you have no visable leaks switch ASAP.
Old Oct 29, 2010 | 09:13 AM
75ohm's Avatar
I would not take a car with a 100K miles that ran on dino and switched it to synth... you're asking for trouble with seals and leaks.
Old Oct 31, 2010 | 06:57 PM
Bingo...
BenHur
Sep 8, 2015 09:29 PM
urbino
Jul 31, 2014 10:17 AM
neil16377
Feb 22, 2012 05:25 AM
Arsenal6
Apr 26, 2009 02:34 AM
banditz71
May 31, 2008 03:20 AM
