So i changed the battery....
Old Oct 14, 2013 | 09:43 AM
akabond's Avatar
Default So i changed the battery....
old battery was low ( but not dead) so i bought OEM from the dealer. Plus the old one lasted me like 7 years . anyways the reason i am posting that i was reading online and on youtube that before and after changing the battery one need to do some kind of calibration ( like turn the key on II position or open and close the sunroof couple of time etc) in order to reset the computer.
But when i read the owners manual on my 2006 S80 2.5T there was no mention about this at all.
Its just a simple remove the old one and put in new one
And thats what i did with no problems. The car started up just fine and there was no problems in electronics in the car.
I was going to do a DIY but its actually pretty straight forward.
Old Oct 14, 2013 | 11:13 AM
majorcode's Avatar
akabond, thanks for update. I changed mine last month but soon after changing i am facing issues...like some times when my car is warm enough or 100 KM drive after...though I changed exactly the way you did......but when I turn off the car and start again, my RPM zooms up and down....any suggestions?
Old Oct 14, 2013 | 11:47 AM
akabond's Avatar
looks like yours is a different year and engine. did you read the manual about any calibration and/or talked to the dealer just to get their opinion about replacing battery. i had to ask the dealer too when i was there to get the new battery and they 1st asked what kind of engine. so maybe that might be a factor.
But you said after a month. so could be something else. You only mentioned that the issue is rpm goes up and down. that could be some minor electronic signal . mine did that too but on my old battery and it was random. With the new one it stopped.
As you know older S80s have lot of electrical problems
Old Oct 14, 2013 | 08:55 PM
quietlymknnoise's Avatar
I also just changed out the battery in our '06 S80 2.5T. I turned off the A/C system and the radio. The radio worked with no code needed and A/C blew cold air. No problems in over a week.
Old Oct 17, 2013 | 07:00 PM
majorcode's Avatar
We got winters here from few days its working fine, so I am sure either my Starter cables are culprit or Starter it self. Thanks.
Domas
Dec 7, 2007 10:01 AM
Royalty
Oct 4, 2007 12:16 PM
Raging Demon
Jun 14, 2007 07:39 PM
patrickpar
Oct 26, 2006 11:17 AM
cava
Jul 28, 2006 05:39 PM
