SRS Urgent Service
Old Apr 22, 2010 | 02:40 PM
smithpaw's Avatar
Default SRS Urgent Service
The SRS Urgent Service required is displayed in the information display. Had the car scanned at my local mechanic and he indicated it was a lamp display code. I thought the best method was to take it to a certified Volvo dealer and have them scan it. I have attached the results in PDF. The tech indicates he would have to do a further diagnosis and likely pull the insturment panel out. He has only seen the code once and replacing the instrument panel was the fix. This a $1000.00 plus fix but nothing is wrong with the airbag system. Looking for other options. It is a shame to have this safety feature not operating in a vehicle which prides itself on safety.
Old Apr 25, 2010 | 04:47 PM
air force rascal's Avatar
I would find a friend that has a scanner that can clear srs and clear it to see if it comes back..if it doesn't come back then nothings wrong..I wouldn't pay 1 k right off the bat....
Old Apr 25, 2010 | 07:26 PM
537playing's Avatar
I would look up how to reset the service light. Based on your PDF file, that is your only error which is the service light on.
Old Apr 27, 2010 | 02:34 PM
magda's Avatar
Default srs airbag urgent
I have 00 Volvo s80 since 6 months. It was never crushed. srs airbag urgent message and airbag light showed about one month ago. I tried to cancel it but my mechanic couldn't do it. I decided to go to volvo service. I paid them €150 for diagnostic. They told that contact reel need to be replaced. I paid them €200 for new part and €120 for replace it. Then they told me that there is a problem with airbags in driver and passenger seat. Can someone tell me what is going on? I can't bieleve it!!!
Old Apr 30, 2010 | 01:30 AM
jdaniels30's Avatar
I have a 2004 Volvo S80 T6. I was in a minor fender bender the other day. After the accident the car ran for about 5 miles then the engine began to spuutter. Stopped the car. Then when I try to start the car it cranks but does not start. There is a line where it shows what gear the car is in. Then there is two error messages: SRS Airbag Urgent Service. Then it has Anti Lock brake Service. Check engine light is on. Anyone have any ideas?
Old Apr 30, 2010 | 03:12 PM
75ohm's Avatar
All that stuff started on our car when the ABS unit starting going goofy...
Old May 2, 2010 | 10:05 PM
szobell's Avatar
Default SRS Reset Service
Has anyone tried one of the SRS Reset Services? Say they can reset the module for $49.95.
Sounds too good to be true.... (which means)
robingichuhi
Feb 22, 2017 04:34 PM
gordon368
Feb 7, 2017 02:56 AM
giannis-21
Aug 10, 2011 01:50 PM
casique
Feb 10, 2007 10:38 PM
mingster
May 2, 2006 11:08 PM
