Steering whine, rubbing tires 02 s80
Old Aug 20, 2009 | 12:57 PM
silverbyte's Avatar
Default Steering whine, rubbing tires 02 s80
Hi, just joined forum and have problems and a question. (2002 S80 T6)
Problems: 1. Whining from under hood when turning steering wheel, even just a little bit and at full stop. 2. Replaced tires with Kumho factory specs and they rub the wheelwell both sides. Mechanic says this is common, can't I live with it! Really?
Question: Where can I get a list of dash messages and their purpose? Latest one is "no skid system needs servicing". Certainly these are compiled somewhere! Thanks
Old Aug 20, 2009 | 05:30 PM
peetek's Avatar
whining is usually low power steering fluid and yes, the tires always rub, I had Kumhos and now have yokohamas and they always rubbed when turning the wheel all the way!
Old Aug 21, 2009 | 02:21 PM
drabina's Avatar
I have 2003 T6 with 17" wheels and my tires rub as well (when turned to the max). I guess we have to live with it.
Old Sep 11, 2009 | 03:43 AM
carlover99's Avatar
Uhh... the rub is not normal.. You have a worn out steering bump stopper. its on the knuckle; little cyclinder looking things ... you can see it if you put your head down and look at the lower inner section of the suspension and Youll probably see a worn out bushing. Id say its about 1x2 inch cylinder shape. Mounted by 13mm bolts on each end. thats what I was shown when the mechanic lifted my car up.
Old Sep 15, 2009 | 09:55 PM
subdewd's Avatar
agree steering stops. When you have a car with such a large turning radius it's
always tempting to nudge the wheel a little harder. I'm on the third set.
The whining from my s 80 is my wife!
Old Sep 28, 2009 | 02:51 PM
brobabs80's Avatar
Default Kumho's too
I had the exact same problem. 2003 S80 T6. went from OEM michelins to Kumho. Got the rubbing on both sides. mechanic said it was common with the kumhos even though they are the same size as the michelins. 40,000 miles later, just put on a set of yokohamas - no rubbing noise.
sjv13
Apr 21, 2011 06:47 AM
jay
May 15, 2010 08:29 AM
volvoitis
Feb 1, 2010 06:59 AM
endneu913
Jul 2, 2008 02:06 AM
vicki
May 12, 2005 09:37 PM
