Surging at idle
Old Dec 9, 2006 | 08:02 PM
worldspeaker's Avatar
Default Surging at idle
Hi everyone,
I have a 99 S80 with the 2.9 and it has developed a surge at idle. It is fine when cold but once it warms up it surges from approximately 650 to 1200 RPMs. It is a constant rythm with a slight "air escaping" sound coming from the area of the intake. Have checked all hoses and can't find a leak. It is my fiance's car so I am not all that familiar with it's other quirks yet. Any ideas anyone?
Dave
Old Dec 9, 2006 | 11:01 PM
Default RE: Surging at idle
Has it had the ETM recall software?
Old Dec 10, 2006 | 02:23 PM
I believe so. My fiance got the car in 2003 and the original owner said that she had recall work done on the car.
Dave
Old Dec 10, 2006 | 10:50 PM
I would Double check with the Dealer the Recall came out last year or early this year.
The Dealer can run the Vin# and tell you if there is a open recall.
Old Dec 11, 2006 | 01:20 PM
I ran the vin number and there is not an open recall for it. Too bad, that might have been a real easy fix. Any other suggestions, I really appreciate your help.
Dave
Old Dec 11, 2006 | 06:04 PM
v70 2.4t's Avatar
ORIGINAL: worldspeaker
Dave
I would double check, S80's manufactured between 5/11/98 to 8/27/01 are involved in the recall.
V70 2.4t
Old Dec 11, 2006 | 09:21 PM
If the software has been done then try to get the check engine light to come on with throttle body codes and they will replace it for free.
Has the check engine light been on?
Has the throttle body been cleaned lately?
Old Dec 21, 2006 | 08:24 PM
I talked to another dealer today and he said there is a recall and they will download the software tomorrow morning (recall 155). Thank you for your info. Hopefully this will take care of that situation.
Another question, do you need any special tools to put struts on the 99 S 80 or is it a fairly easy switchout?
Thank you again for all your help,
Dave
Old Dec 21, 2006 | 09:40 PM
You really should have a special wrench to remove the second nut.
BUT a Pipe wrench will work good as well.
You will need a torxes socket as well to hold the center of the strut.
Old Dec 23, 2006 | 01:21 AM
You are a genius! They downloaded the software and it runs great! At the dealer I pulled up next to two other S80's with the same problem. They all almost surged in unison!
They told me the struts are fine but the seats above the struts are broken. Will I need a special tool for that repair?
They also said the top motor mount is broken. I am going to replace that too.
Your help has been amazing.
Dave
Old Dec 23, 2006 | 02:07 AM
You can use a pipe wrench and torxes socket to remove the Nut.
You need a spring compressor to compress the spring.
palebeachbum
Sep 28, 2010 05:50 PM
tracyfend
Feb 22, 2010 12:14 PM
Tarheel Taxi
Nov 11, 2009 08:01 PM
outdoor7or24
Sep 17, 2008 09:26 AM
Richard74
Jul 22, 2006 12:39 AM
