TECH HELP!! Steering groan & front-end clunking
Old Jul 18, 2007 | 03:05 PM
ferraramp's Avatar
Default TECH HELP!! Steering groan & front-end clunking
2006 S80 AWD, 8500 miles, 18" wheels-- Getting a loud groaning when turning - key is this only happens with slight pressure on gas pedal (I can turn the wheel all day at a dead stop, and no sound) -- so this usually happens in slow turns/approaches. Dealer has 1) said system was "air bound" and filled fluid to power steering, and 2) 2'nd visit, replasced the power steering pump -- just got worse again -- starting to think this is drive-train/AWD issue?
Also getting the thumping/clunking sound from the front end -- again, usually slow, bigturns with bumps (like a hard right). Dealer says they cannot "reproduce" the sound, yet I get it every time I get into the car.
Love the car, hate the problems -- Any help is much appreciated.
Old Jul 18, 2007 | 05:44 PM
Default RE: TECH HELP!! Steering groan & front-end clunking
Maybe the fluid bottle is bad for the steering.
Suspension check the strut caps/ and sway bar links.
Possible it is a AWD issue but I would rule everything else out first.
Old Jul 20, 2007 | 04:38 AM
gordon368's Avatar
i had that moaning sound while turning too, the hose near my power steering tank turned out to be mangled/twisted/pullled/bent, a new hose clamp solved it.
Wing0
Dec 13, 2013 02:39 PM
Wagood24
Jul 28, 2012 10:34 PM
S70driver
Nov 23, 2007 10:08 PM
jnd28
Sep 7, 2007 10:38 AM
nolavolvo
Feb 7, 2007 08:58 PM
